Python netmiko: How to print out specific line matches with 'Cisco IOS Software' in the 'show version' command?
write_erase
This is sample output of Cisco Switch show version command.
Switch#show version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 15.0(2)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Objective: If string `Cisco IOS Software` is found in the 'show version' output, I would like to print the whole line.
To make it easier to understand, let me put `show version` output in `shvar` variable
shvar = '''
There are 2 ways that I know of to find something ...
1. Search with `if`
>>> if 'Cisco IOS Software' in shvar:
... print('Found ... print line')
Or
2. Search with `find()`
>>> if shvar.find('Cisco IOS Software') > 0:
The question is how do I print the line matches with 'Cisco IOS Software' instead of just showing "Found ... print line" output?
Desired Output
omz
You could do something like this -
#!/usr/bin/env python
from netmiko import ConnectHandler
import re
cisco_881 = {
'device_type': 'cisco_ios',
'host': '192.168.106.153',
'username': 'cisco',
'password': 'cisco',
'port': '22'
net_connect = ConnectHandler(**cisco_881)
output = net_connect.send_command('',expect_string=r'#',strip_command=False, strip_prompt=False)
output += net_connect.send_command('show version',expect_string=r'#',strip_command=False, strip_prompt=False)
net_connect.disconnect()
IOS_RE = r'(Cisco IOS\s+(\S+\s+.*))'
matched = re.findall(IOS_RE,output)
print(matched[0][0])
Output
omz
import re
cisco_881 = {
'port': '22'
Output
