Rest API using Python
Any one here using Python with requests to give me some guidance or basic script examples ?  All I got so far was the html code from Prime.
Thanks in advanced.
Gallifrean
Level 7
Level 7
have you seen this
"import requests resp = requests.get('https://todolist.example.com/tasks/') if resp.status_code != 200:    # This means something went wrong.    raise ApiError('GET /tasks/ {}'.format(resp.status_code)) for todo_item in resp.json():    print('{} {}'.format(todo_item['id'], todo_item['summary'])) "
Source
aradford
brian420
Community Member
HTML? Do you mean URL?
APIs use URLs and JSON.
What exactly are you trying to do?
