Using Ansible to remove authentication open for ISE enforcement
waqas gondal
I am working on putting ISE into enforcement mode on production switches for 802.1x wired auth.
Currently the access interfaces all have authentication open which needs to be removed.
I have Ansible installed and ready to configure switches.
Is there anyway I could configure a playbook to find any interfaces that have 'authentication open' and remove it? It would help if this same playbook could be used to revert if enforcement doesn't work.
This type of config would also help switch to c3pl down the road.
Thanks!
Waqas
0 Replies 0
