Cisco ACI Simulator 4.2 on Devnet Sandbox has problem during Activation
Va.8427
Level 2
Level 2
as you can see, there is a problem in Cisco ACI Lab during the activation process. Finally, it shows Completed!
any idea?
Hello, @Va.8427 there can be issues in set up, the QA detects these on the build. Try and cancel the current reservation, and spin up a new one. If these same errors persist you can share the logs from the output window for further troubleshooting.
Hope this helps!
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
