CML sandbox for home connections
mikelee4356
Hello:
I have setup a sandbox environment for vxlan-evpn, and want to test with Ansible, but I could not make management interface working with bridge mode? nor I could ping the management interface from my laptop, default CML sandbox is working find, did I miss anything?
Appreciate any help..
~Mike
@mikelee4356 Connecter in Bridge mode, Interface in management VRF should all thats required.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
@bigevilbeard
how is the routing setup for the vpn client? If I assign my home network range to management interface on CML?
do you have any documentation?
~Mike
Not sure who changed the default lab, I could not ping 8.8.8.8 now,
interface mgmt0
description to port8.sandbox-backend
duplex full
vrf member management
ip address 10.10.20.177/24
dist-sw01# ping 8.8.8.8 vrf management
PING 8.8.8.8 (8.8.8.8): 56 data bytes
Request 0 timed out
Request 1 timed out
Request 2 timed out
CRequest 3 timed out
^C
~Mike
