Connection issues with OSC FCS Lab
monasterios
I'm having connection issues to the OSC FCS lab. I connected successfully through Cisco AnyConnect using the credentials sent to me by email. Once connected I get an IP address on the 172.16.255.0/24 subnet:
Connection-specific DNS Suffix  . : abc.inc
Link-local IPv6 Address . . . . . : fe80::6800:7fcc:df3f:fa0%47
Link-local IPv6 Address . . . . . : fe80::c353:c03c:20df:cd16%47
IPv4 Address. . . . . . . . . . . : 172.16.255.18
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : ::
I get routes for 3 subnets,
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
        10.10.0.0      255.255.0.0     172.16.255.1    172.16.255.18      2
       172.16.1.0    255.255.255.0     172.16.255.1    172.16.255.18      2
     172.16.255.0    255.255.255.0     172.16.255.1    172.16.255.18      2
The only devices I can ping, SSH/Telnet to are:
10.10.10.150
10.10.10.151
10.10.10.152
10.10.10.254
I cannot reach the OSC-Server or any of the IOSXRV devices. I also tried HTTP/HTTPS and do not get any response back.
Thanks for helping.
6 Replies 6
ecorban
hi diego
do you have an active reservation ? Of so i will check your session and see if there is an issue with the spinup of the lab topology.
thanks
eddie
Yes, I do.
Any updates? Are you able to find my reservation with my Cisco account or do you need additional information?
We found your reservation and re-initialized the controller orchestration. it is coming online now. we will investigate the iosxrv nodes and see if there is an issue.
Hey Eddie,
I'm now able to reach the OSC Controller and all XRv devices! However, i'm still unable to reach the OSC-server and all 4 Ubuntu hosts:
osc-server: 10.10.10.146
host1: 10.10.20.101
host2: 10.10.20.102
host3: 10.10.20.103
host4: 10.10.20.105
Can you look into it?
those hosts are currently offline. please continue with your reservation as we will try to resolve the issue....
