Issue connecting to VPN on devnet
Geoffrey Novak
Frequent Visitor
Frequent Visitor
My devnet vpn isn't allowing me to connect as shown below. I've never had this issue before, not sure why my credentials from the e-mail aren't working.
Geoffrey Novak
Frequent Visitor
Frequent Visitor
Looks like an issue with me being on Marriott's wifi as my MiFi works. I think it's the non-standard VPN port.
Nitin1
Community Member
Hello Team,
Can you please reply to this post?
I just reserve the lab for first time and I am not able to connect to VPN. Do I need to off the Firewall or antivirus settings or some other settings needs to be done? Please update soon.
Nitin Patil
Hi Nitin,
Please check:
- Is your reservation "active" now? As you know, sandbox will revoke VPN access once it is completed
- The VPN headend employs :20xxx "high" range port, not standard SSL port 443. Please check if your firewall block this traffic
Bob
