Issues with DevNet Chat(Help)
jpsanchez
Frequent Visitor
Frequent Visitor
Hello, I am trying to reach out to Devnet developer support via https://developer.cisco.com/site/devnet-chat/.
After I input my email and click on a conversation to join, and click Go, nothing happens.
Below is some of the output in the Google Chromes Developer tools when I click on Go.
devnet.cisco.com/v1/pdbm2/users/(Token Removed):1 Failed to load resource: the server responded with a status of 403 (Forbidden)
devnet.cisco.com/v1/sparkmessage/memberships/?userEmail=(RemovingMyEmail)&roomId=Y2lzY29zcGFyazovL3VzL1JPT00vYzQ2OTk3NTAtZGIyNy0xMWU1LWI0ZjQtZmJmMjI3Y2ZmYWYz:1 Failed to load resource: the server responded with a status of 400 (Bad Request)
devnet.cisco.com/v1/sparkmessage/memberships/?userEmail=RemovingMyEmail&roomId=Y2lzY29zcGFyazovL3VzL1JPT00vNGZlOTQ2MTAtZjA2MS0xMWU1LWI4Y2UtMTEzZjhkZmMxNGJl:1 Failed to load resource: the server responded with a status of 400 (Bad Request)
devnet.cisco.com/v1/sparkmessage/memberships/?userEmail=RemovingMyEmail&roomId=Y2lzY29zcGFyazovL3VzL1JPT00vZDJmZGUwOTAtOWQwYy0xMWU1LWFlZWQtMjE3NmZkY2Q4YTU4:1 Failed to load resource: the server responded with a status of 400 (Bad Request)
devnet.cisco.com/v1/sparkmessage/memberships/:1 Failed to load resource: the server responded with a status of 400 (Bad Request)
(index):1 Access to XMLHttpRequest at 'https://www.google-analytics.com/j/collect?v= from origin 'https://developer.cisco.com' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: The value of the 'Access-Control-Allow-Origin' header in the response must not be the wildcard '*' when the request's credentials mode is 'include'. The credentials mode of requests initiated by the XMLHttpRequest is controlled by the withCredentials attribute.
 @jpsanchez send me your email via the 1:1 message here, I will try and add you.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
