Lab active with error
cmarquette
Visitor
Lab is active with error and there's no sign of the VPN access instruction email.
Activity Feed errors:
'Setup' Blueprint command on 'Multi-IOS Cisco Test Network' failed with 'Resource Command Error' error
Error: Resource Command Error
Description: A Resource Command error has occurred. Lab setup failed.
Parameters:
'Setup' resource command on 'VIRL Server_82d1b118' failed with 'Driver Failed' error
Error: Driver Failed
Description: Developer Mode setup has failed
Parameters:
Please advise.
Ollie Y
Level 2
Level 2
I also have this issue on the "IOS XE on Catalyst 9000 16.12 EFT Code" sandbox.
ERROR detected when calling Resource Driver Command [Setup] for resource [Catalyst 9000-1].
Friendly Error Message: Failed to login to in-lab DevBox
Technical Error Message: Failed to login to in-lab DevBox
Error Location: UHD_RD_IOSXE_Catalyst_9000_Baseline:remote_test_C9K.SSH Remote Test
