Mac AnyConnect Client for DevNet Sandbox will not connect
Eric R. Jones
Level 8
Level 8
I installed AnyConnect version 4.9.04043 on my iMac Ventura 13.3.1, and when the lab is done downloading I get my password and attempt to login. Nothing happens. I get a "Login failed". The prefilled in sections are SSLClient and my username. The AnyConnect window shows Login Failed and a grayed "devnetsandbox-usw1-reservation.cisco". I don't know if that is matching what is the output window since I can't see the entire line in the mobility client. I've checked my ports and 20000 to 22000 is allowed and there's nothing in the logs showing a block.
I had this working about a year ago but it's not working now. I've already uninstalled it once having to make sure I used the pkgutil for the package.
Any thoughts.
ej
Try using OpenConnect
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
ok, I'll try that. Figured the anyconnect was tied in DevNet wouldn't accept another app. Not sure why I thought this just got locked in.
