Need an ACI instance to build an integration for it from VMware
ctr000001
Hi all - We are in need of access to a Cisco ACI environment that can support VMware to build some automaton for an open source TOSCA model to allow IaaS support for CIsco ACI.  How is the best way to get access to an ACI system to do some integration work and testing for it?  Many thanks for all who can help.
creynolds@tsieda.com
@ctr000001 is there anything suitable for you in the https://devnetsandbox.cisco.com/ or https://dcloud.cisco.com/?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
We don't think this will work - we need an ACI instance that is accessible from a VMware installation as our integration shell works in VMware and needs to flow into ACI and control things there. We would welcome a technical session to understand what our options are to facilitate a development and testing platform.
Hello @ctr000001 devnet does not / cannot build bespoke environments for customer use. I would suggest making this request for a development and testing platform to your Cisco account manager who would be able to speak with CPOC/dCloud to see if this is
sort of POV they might set up with the account team something they will build.
Hope this helps.
