Nxos netconf problem
Adraf0001
Community Member
when I try and open a netconf session to the nxos always on sandbox with the below command from my Ubuntu terminal,
ssh [email protected] -p 10000
it logs me into the switch but it doesn’t start netconf.
Adeel
Test NETCONF directly with XMLAgent with xmlagent. (The xmlagent service is referred to as the XML server in Cisco NX-OS software). Hope this helps.
(venv) $ ssh [email protected] -p 10000 xmlagent
Welcome to the DevNet Always On Sandbox for Open NX-OS
This is a shared sandbox available for anyone to use to
test APIs, explore features, and test scripts.  Please
keep this in mind as you use it, and respect others use.
The following programmability features are already enabled:
  - NX-API
  - NETCONF, RESTCONF, gRPC
  - Native NX-OS and OpenConfig YANG Models
Thanks for stopping by.
Password:
<?xml version="1.0" encoding="ISO-8859-1"?>
<hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <capabilities>
    <capability>urn:ietf:params:xml:ns:netconf:base:1.0</capability>
    <capability>urn:ietf:params:netconf:base:1.0</capability>
    <capability>urn:ietf:params:netconf:capability:validate:1.0</capability>
    <capability>urn:ietf:params:netconf:capability:writable-running:1.0</capability>
    <capability>urn:ietf:params:netconf:capability:url:1.0?scheme=file</capability>
    <capability>urn:ietf:params:netconf:capability:rollback-on-error:1.0</capability>
    <capability>urn:ietf:params:netconf:capability:candidate:1.0</capability>
    <capability>urn:ietf:params:netconf:capability:confirmed-commit:1.0</capability>
  </capabilities>
  <session-id>28229</session-id>
</hello>
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
That’s great. I will give that a go. Thanks a lot for your help Stuart.
Adeel
