OCG DEVASC Chapter 8 DNA Center Python SDK Example 8-7
AFlack20
Level 3
Level 3
This is more of a basic python question than anything.
Working through the Official Cert Guide for DevNet associate and in chapter 8 example 8-7 for the DNA center SDK I'm running into an issue. When looping through the devices with the (for DEVICE in DEVICES.response:) it is returning 3 additional devices that are not shown in figure 8-10 of chapter 8, with values of None. I can print this without the formatting, but python throws and exception when the formatting is present.
Now I was thinking I could avoid this exception with an additional if clause but for reasons I don't understand as of yet, python doesn't take the final (else:) with a following print statement.
First can someone please explain my error (specifically between lines 14 - 25)? Secondly is this the best method for working through this particular issue or should I just be doing error handling on the formatting exception? Thanks!
from dnacentersdk import api
DNAC = api.DNACenterAPI(username='devnetuser',
    password='Cisco123!',
    base_url='https://sandboxdnac2.cisco.com/dna')
DEVICES = DNAC.devices.get_device_list()
print('{0:25s}{1:1}{2:45}{3:1}{4:15s}'.format('Device Name', '|', \
    'Device Type', '|', 'Up Time'))
print('-'*95)
    if DEVICE.hostname == None:
        pass
    elif DEVICE.type == None:
        pass
    elif DEVICE.upTime == None:
        pass
    else:
        print(('{0:25}{1:1}{2:45}{3:1}{4:15}'.format(DEVICE.hostname, \
            '|', DEVICE.type, '|', DEVICE.upTime))
print('-'*95)
CLIENTS = DNAC.clients.get_overall_client_health(timestamp='')
print('{0:25s}{1:1}{2:45}{3:1}{4:15s}'.format('Client Category', '|', \
    'Number of Clients', '|', 'Clients Score'))
print('-'*95)
for CLIENT in CLIENTS.response:
    for score in CLIENT.scoreDetail:
        print('{0:25s}{1:1}{2:<45d}{3:1}{4:<15d}'.format(
            score.scoreCategory.value, '|', score.clientCount, '|', \
            score.scoreValue))
print('-'*95)
@AFlack20 i would post this over in the devnet cert forum here --> https://learningnetwork.cisco.com/s/topic/0TO3i0000008jY5GAI/devnet-certifications-community
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
AFlack20
Level 3
Level 3
Will do, Thanks!
