Sandbox APIC missing switches?
Tromano89
Community Member
I logged onto the "Always on" Sandbox ACI simulator this morning and noticed that there's no spine or leaf switches? Looking at the documentation there should be a spine and 2 leaf switches but the only device showing up in the topology is the APIC itself, pod 1 is empty.
I`m not sure if I`m missing something or if there's an issue, anyone else seeing the same?
hTariq
Visitor
I just accessed the Sandbox and find the same issue trying to Fix it. Will get back to You. I don't have access to Console lines nor I'm from Cisco.
ecorban
Thanks for the information. this issue should now be resolved.
Dear ecorban
same issue now . could please support no spine and leaf switch in apic
Marcel Zehnder
You may need to discover the spines and leaves in a first step: Fabric --> Inventory --> Fabric Membership --> Nodes Pending Registration.
See for example this guide for more info: https://www.cisco.com/c/en/us/td/docs/dcn/aci/apic/5x/getting-started/cisco-apic-getting-started-guide-52x/fabric-initialization-52x.html#id_46142
