Sandbox Lab Not Found
spencera
I've been trying to find a sandbox to build a basic configuration to demonstrate HSRP but the two CML sites I've been trying to access have been offline for several weeks:
     NX-OS with 6 VIRL License: http://bit.ly/2zph9fc
     Multi-IOS VIRL (larger server): http://bit.ly/2PPd8ut
Have these sites bee decomissioned or is there an alternate environment I should be using to setup a small prototype/demonstration?  Thanks in advance...
@spencera the two sandbox you refer to are both built on VIRL - both are undergoing work/maintenance. You can use the following two CML sandbox
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
