SPARK APIC lab - traceback on check_dcloud.py
Steve Simlo
I am working here:
Cisco DevNet Learning Labs
I can SSH into the UBUNTU machine in the DCLOUD Sandbox:
SSIMLO-M-D00G:LM-4302 ssimlo$ ssh cisco@198.18.134.28
cisco@198.18.134.28's password:
Welcome to Ubuntu 14.04.5 LTS (GNU/Linux 4.4.0-42-generic x86_64)
* Documentation:  https://help.ubuntu.com/
206 packages can be updated.
148 updates are security updates.
Your Hardware Enablement Stack (HWE) is supported until April 2019.
Last login: Mon Jun 12 17:26:58 2017 from 10.16.51.148
Code-Samples were successfully updated.
Happy Coding!!!
(dna) cisco@ubuntu:~/CiscoDevNet/code/dna$
When I try to run the check_dcloud.py I get a traceback:
(dna) cisco@ubuntu:~/CiscoDevNet/code/dna/LM-4302$ python3 check_dcloud.py
Traceback (most recent call last):
  File "check_dcloud.py", line 9, in <module>
    from hello_lab import APIC_EM_URL
  File "/home/cisco/CiscoDevNet/code/dna/LM-4302/hello_lab.py", line 81, in <module>
    room_id = spark_get_room_id(SPARK_TOKN, SPARK_ROOM)
  File "/home/cisco/CiscoDevNet/code/dna/LM-4302/myspark.py", line 42, in spark_get_room_id
    r = requests.get(uri, params=query, headers=_headers(token))
  File "/home/cisco/CiscoDevNet/code/dna/LM-4302/myspark.py", line 15, in _headers
    'Authorization': 'Bearer ' + token}
TypeError: Can't convert 'NoneType' object to str implicitly
I posted in the
but got no reply
I opened a case with dCloud and they pointed me back here
Steve Simlo
I just span up another lab to see if the fault disappeared and it did not so it was not an issue specific to the instances I span up
hi ssimlo
we will get back to you with an answer ASAP.
thanks
eddie
armartir
Community Member
Hi Steve,
In order to successfully run the check_dcloud.py script fist you will need to populate SPARK_TOKN and SPARK_ROOM variables located in hello_lab.py file.
Spark token can be obtained from https://developer.ciscospark.com/ page. After successful authentication, click on your avatar picture and access token will be displayed.
From Cisco Spark, pick a room where you would like to post a message and assign it to the SPARK_ROOM variable.
After that run the script and you should see a message on your terminal confirming that dCloud pod is ready for the labs.
PS. I will update the script so it will notify the user that important variables need to be populated.
Thank you!
Armen M.
