Unable to connect ISE Sandbox
khalidhashmi
I am unable to connect ISE Sandbox via OpenConnect VPN, it gets connected but somehow it immediately disconnected as well
2025-04-15 01:39:30 | 702c | Got CONNECT response: HTTP/1.1 200 OK
2025-04-15 01:39:30 | 702c | CSTP connected. DPD 30, Keepalive 20
2025-04-15 01:39:31 | 702c | Established DTLS connection (using GnuTLS). Ciphersuite (DTLS1.2)-(ECDHE-RSA)-(AES-256-GCM).
2025-04-15 01:39:31 | 702c | DTLS connection compression using LZS.
2025-04-15 01:39:31 | 702c | Using generated interface name devnetsandbox-usw1-reservation.cisco.com_a8e9c438
2025-04-15 01:39:31 | 702c | Script 'C:/Program Files/OpenConnect-GUI\vpnc-script.js' returned error 1
2025-04-15 01:39:31 | 702c | Failed to spawn script 'C:/Program Files/OpenConnect-GUI\vpnc-script.js' for pre-init: The operation completed successfully.
2025-04-15 01:39:31 | 702c | 0: Using existing driver 0.14
2025-04-15 01:39:31 | 702c | 0: Creating adapter
2025-04-15 01:39:32 | 702c | Cannot read registry key SYSTEM\CurrentControlSet\Control\Network\{4D36E972-E325-11CE-BFC1-08002BE10318}\{DF9D48AD-A2AD-404F-94A2-A51D52CC65C7}\Connection\Name or is not string
2025-04-15 01:39:32 | 702c | Could not open C:\Users\mkhal\AppData\Local\Temp\vpnc.log: The system cannot find the file specified.
2025-04-15 01:39:32 | 702c | Script 'C:/Program Files/OpenConnect-GUI\vpnc-script.js' returned error 1
2025-04-15 01:39:32 | 702c | Failed to spawn script 'C:/Program Files/OpenConnect-GUI\vpnc-script.js' for pre-init: The operation completed successfully.
2025-04-15 01:39:32 | 702c | 0: Using existing driver 0.14
2025-04-15 01:39:32 | 702c | 0: Creating adapter
2025-04-15 01:39:33 | 702c | Cannot read registry key SYSTEM\CurrentControlSet\Control\Network\{4D36E972-E325-11CE-BFC1-08002BE10318}\{FB8CBC4C-086D-4258-9BE5-306E8FE156B3}\Connection\Name or is not string
2025-04-15 01:39:33 | 702c | Set up tun device failed
2025-04-15 01:39:33 | 702c | Send BYE packet: Set up tun device failed
2025-04-15 01:39:33 | 702c | Could not open C:\Users\mkhal\AppData\Local\Temp\vpnc.log: The system cannot find the file specified.
2025-04-15 01:39:33 | 2668 | Disconnected
Try the solution here https://community.cisco.com/t5/devnet-sandbox/devnet-sandbox-openconnect-failure/td-p/5270922
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
