Wireless adapters and devices in CML Sandbox
Jaffa
I've been using a CML sandbox instance to test 802.1x with radius authentication. I have succeeded in configuring this on a wired connection, but I cant see a way to add a node with a wireless adapter, or add a wireless adapter to a existing node. I can see I can add a virtual wireless Lan controller node, but there doesn't appear to be any access points. Am I missing something obvious here?
Kind regards
Jacob
2 Accepted Solutions
@Jaffa as far as i am aware there are no APs in the sandboxes. Happy to be wrong on this, but this is what i recalled when this was asked before.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Jens Albrecht
Hello @Jaffa,
as @bigevilbeard mentioned, CML does currently not contain any APs or wireless endpoints.
The addition of the WLC is the first step to add support for wireless into CML. Right now you still need some hardware APs like the good old 2800 or 3800 series that you can get pretty cheap at Ebay.
During the last presentation they mentioned that they have some ideas how to fully support wireless in CML but don't expect that to happen any time soon.
HTH!
Jens Albrecht
Hello @Jaffa,
HTH!
Jaffa
Thank you, @bigevilbeard & @Jens Albrecht , for your responses and insights.
