el 10-25-2022 11:10 AM
I was working in the interconnection N2K-C2248TP with N9K-C93180YC-FX, I could see the N2K in the N9K, when I type show Fex I can see the FEX but in state down and never go up, I don't know they are compatible or I need anything additional in the configuration.
When I did roll back N2k to N5k they are working OK.
The N2K-C2248TP was connecting to N5K with release n5000-uk9.5.2.1.N1.4.bin and working ok and the N9K with release nxos.9.3.10.bin.
The Configuration is same in both SWs (N5K & N9K)
allow feature-set fex
limit-resource vlan minimum 16 maximum 4094
limit-resource vrf minimum 2 maximum 4096
limit-resource port-channel minimum 0 maximum 511
limit-resource u4route-mem minimum 248 maximum 248
limit-resource u6route-mem minimum 96 maximum 96
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
feature-set fex
fex 151
pinning max-links 1
description "FEX0151"
port-profile type port-channel PC-FEX
switchport mode fex-fabric
storm-control broadcast level 1.00
storm-control multicast level 1.00
state enabled
interface port-channel151
description FEX151
switchport
fex associate 151
logging event port link-status
speed 10000
vpc 151
mtu 9216
inherit port-profile PC-FEX
interface Ethernet1/1
description Po151.1-FEX151/P1
switchport
fex associate 151
speed 10000
channel-group 151 mode active
no shutdown
I hope your answer
el 10-25-2022 11:40 AM
As per the support concern, it is supported.
https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/fexmatrix/fexmatrix.html
is the nexus 9K in vPC.
I default the config of interface make it simple config to work, before proceed to extra config :
description FEX151
switchport
fex associate 151
speed 10000
vpc 151
switchport
fex associate 151
speed 10000
no shutdown
then post the below output :
show interface Ethernet1/1 trans
show fex
show interface status fex 151
show interface fex-fabric
el 10-25-2022 12:01 PM
Hi, I eliminate the port-chaannel and configured only physical interface e1/1 but it not worked neither
el 10-25-2022 12:15 PM
I saw in the matrix that the N2K is compatible in release 7.0(3)I5(1).
Could be a problem because I have release 9.3.10 in N9K and the N5K was working is release n5000-uk9.5.2.1.N1.4.bin when it was parent to the N2K?
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
