cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
6
Respuestas
Nexus 9K - Jumbo Frame / MTU config
babalao
what would be the config if I want to enable Jumbo frames for this requirement (see draw attached please).
I want to enable jumbo frames among all 3 servers. The switch is a Nexus 93XX.
Server 1 and 2 are on the same VLAN.
Server 3 is on another VLAN.
What do I need to configure ? Only physical eth ports? and the SVIs too?
Please help.
Thank you in advance.
Regards.
6 RESPUESTAS 6
M02@rt37
Hello @babalao,
What is the Nexus IOS version please.
Thanks.
Best regards
babalao
version 10.2(5)
thanks.
@babalao,
Please refer here
http://netterrene.blogspot.com/2020/01/jumbo-frame-configuration-on-nexus.html?m=1
Best regards
babalao
I have read that doc and others but I still have doubts.
for example in my example, If it is intra VLAN I only need to enable it (mtu 9216) on the L2 ethernet interfaces ?
And if it is inter VLAN, only then I need to enable it on the SVIs (plus the L2 ethernet interfaces) ??
So what set of commands would be necessary to accomplish what I originally posted in that simple topology?
Thank you!
babalao
can anybody help me with what I asked please?
Thak you!
Regards.
M02@rt37
Hello @babalao,
To enable Jumbo frames on your Nexus 9300 switch for the servers and SVIs, you'll need to make configurations on both the physical Ethernet interfaces and the SVIs.
Best regards
