el 04-25-2025 04:29 PM
Hi everyone, I'm having a problem. I wanted to filter social networks as blue with F on a specific Windows desktop installed on an Apple computer, and it's not filtering correctly through the social network's ACL. What else could I add to ensure the ACL correctly filters the HTTP, HTTPS, and HTTP/3 – QUIC protocols? It's worth mentioning that only that device has this problem.
Note: I have a Cisco 2911 router.
ip access-list extended BLOCK_FB_IG_WEB mark permit whatsapp permit tcp any 157.240.25.0 0.0.0.255 eq 443 permit tcp any 157.240.14.0 0.0.0.255 eq 443 permit udp any 157.240.25.0 0.0.0.255 eq 3478 permit udp any 157.240.25.0 0.0.0.255 eq 5349 deny tcp any 31.13.24.0 0.0.7.255 eq www deny tcp any 31.13.24.0 0.0.7.255 eq 443 deny tcp any 31.13.64.0 0.0.63.255 eq www deny tcp any 31.13.64.0 0.0.63.255 eq 443 deny tcp any 66.220.144.0 0.0.15.255 eq www deny tcp any 66.220.144.0 0.0.15.255 eq 443 deny tcp any 69.171.224.0 0.0.31.255 eq www deny tcp any 69.171.224.0 0.0.31.255 eq 443 deny tcp any 129.134.0.0 0.0.255.255 eq www deny tcp any 129.134.0.0 0.0.255.255 eq 443 deny tcp any 157.240.0.0 0.0.255.255 eq www deny tcp any 157.240.0.0 0.0.255.255 eq 443 deny tcp any 173.252.64.0 0.0.63.255 eq www deny tcp any 173.252.64.0 0.0.63.255 eq 443 deny tcp any 185.60.216.0 0.0.3.255 eq www deny tcp any 185.60.216.0 0.0.3.255 eq 443 deny tcp any 185.89.216.0 0.0.3.255 eq www deny tcp any 185.89.216.0 0.0.3.255 eq 443 remark QUIC / HTTP-3 (UDP 443) --- deny udp any 31.13.24.0 0.0.7.255 eq 443 deny udp any 31.13.64.0 0.0.63.255 eq 443 deny udp any 66.220.144.0 0.0.15.255 eq 443 deny udp any 69.171.224.0 0.0.31.255 eq 443 deny udp any 129.134.0.0 0.0.255.255 eq 443 deny udp any 157.240.0.0 0.0.255.255 eq 443 deny udp any 173.252.64.0 0.0.63.255 eq 443 deny udp any 185.60.216.0 0.0.3.255 eq 443 deny udp any 185.89.216.0 0.0.3.255 eq 443 permit ip any any
el 04-25-2025 06:00 PM
DNS Filtering
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
