cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Help I can't open cisco packet tracer
drk-fdo22
 Hello when I want to open a packet I can't. When I log in to the Cisco Networking Academy option, I only get the Cisco topics and it doesn't come back to me to make the packet.
 And I saw a solution which was to open it only in the Skill For All option but when I clicked on that button it did not redirect me anywhere, I only got this message. Does anyone know any solution I could do???
3 RESPUESTAS 3
@drk-fdo22
A New browser or tab is opened when you click skill for all. Usually It Will open a Edge browser page. Make sure you dont have It open on the back ground. Check If popup is not blocked in your browser
You can see the message: Login is in progress...a New browser has Been opened....
I had blocked pop-up windows in my browser and activated them. But it still doesn't work and I don't know what to do to solve it. I tried installing the packet tracer again and it's still the same
Blue_Bird
Hello drk-fdo22,
Click on Skill for All  after that you can use your existing G-mail or Google account to login and then it will open pop-up window showing login is success and then you can use your packet tracer..!!
Best regards
******* If This Helps, Please Rate *******
