cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
problem 4.1.5 Check your understanding - Inter-VLAN Routing Operation
wilsons1999
Good evening, I have a problem with the section "4.1.5 Check your understanding - Inter-VLAN Routing Operation" since the quiz does not let me select the 3 correct answers, it only allows me to select all the options, which shows the quiz as incorrect. I would like your support to solve this error, since the same thing happened to me in December and I could not finish the course because it was closed by the academy and I took it again but it still shows me the same problem. Thank you for your attention.
1 RESPUESTA 1
Cosmic Ted
Yeah, same problem here. You can only choose everything => incorrect answer.
