cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
smoke sensor
jhonyconteron
Good afternoon, can you help me, the attached smoke sensor does not
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Your settings are OK.
You just have to modify the environmental conditions so that smoke contamination is faster.
To achieve this, follow these steps.
Select the environment button (top right), and then select the edit button.
Now edit the time scale and leave it as the image.
Then select the advanced button
then scroll down and make sure the smoke box is checked
Finally, save the exercise and reopen it.
I hope this is useful.
Ver la solución en mensaje original publicado
4 RESPUESTAS 4
luis_cordova
Hello
Please zip your exercise(winzip) and attach it for checking.
Greetings
am attaching the file, help me by verifying please, I already did it with another programming and it still doesn't work. I don't know if it's the software (packet tracer 8.2.1) only that sensor doesn't work
thank you very much it helped me
