cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
accessing cisco web configuration UI
alexsssking544
GNS3 Version: GNS3 v2.2.46
Operating System: Windows 10 22H2 19045.4172
GNS3 VM running on VMware® Workstation 17 Player, 17.5.0 build-22583795
hello everyone. i need help with something, i am trying to build a vlan lab
environment. here is the topology:
pfsense works great and i am able to configure everything i need.
however, i can't seem to be able to access the gui for the cisco IOSvL2...
i was able to get pretty close following this "guide" : https://community.cisco.com/t5/switching/9200-enable-web-ui/td-p/4268739
but when i try to acesse the web ui it only displays this:
and when i click "Web Console" :
the client device has 192.168.1.20/24 ip
and the switch has 192.168.1.1/24 ip. and i can ping from client to switch.
so, do i need to make any other configurations to make the web ui show up?
does the cisco IOSvL2 apliance even have a web ui to begin with? if not what other options can i use for a managed switch with a Web GUI?
any help is much appreciated.
thanks in advance!
0 RESPOSTAS 0
