cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Route Reflector
leandro1977
Gostaria de uma ajuda para resolver este lab com RR.
R1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Ethernet0/0
ip address 12.12.12.1 255.255.255.0
interface Ethernet0/1
ip address 14.14.14.1 255.255.255.0
router ospf 1
passive-interface Ethernet0/1
network 12.12.12.0 0.0.0.255 area 0
network 14.14.14.0 0.0.0.255 area 0
router bgp 123
bgp router-id 1.1.1.1
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
neighbor 12.12.12.2 remote-as 123
neighbor 12.12.12.2 next-hop-self
neighbor 14.14.14.4 remote-as 456
R2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 12.12.12.2 255.255.255.0
ip address 23.23.23.2 255.255.255.0
router ospf 1
network 23.23.23.0 0.0.0.255 area 0
router bgp 123
bgp router-id 2.2.2.2
network 2.2.2.2 mask 255.255.255.255
neighbor 12.12.12.1 remote-as 123
neighbor 12.12.12.1 route-reflector-client
neighbor 23.23.23.3 remote-as 123
neighbor 23.23.23.3 route-reflector-client
R3
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip address 36.36.36.3 255.255.255.0
ip address 23.23.23.3 255.255.255.0
router ospf 1
passive-interface Ethernet0/0
network 36.36.36.0 0.0.0.255 area 0
router bgp 123
bgp router-id 3.3.3.3
network 3.3.3.3 mask 255.255.255.255
neighbor 23.23.23.2 remote-as 123
neighbor 23.23.23.2 next-hop-self
neighbor 36.36.36.6 remote-as 456
R4
interface Loopback0
ip address 4.4.4.4 255.255.255.255
ip address 45.45.45.4 255.255.255.0
ip router isis
ip address 14.14.14.4 255.255.255.0
router isis
net 49.0456.0000.0000.0004.00
is-type level-2-only
router bgp 456
bgp router-id 4.4.4.4
network 4.4.4.4 mask 255.255.255.255
neighbor 14.14.14.1 remote-as 123
neighbor 45.45.45.5 remote-as 456
neighbor 45.45.45.5 next-hop-self
R5
interface Loopback0
ip address 5.5.5.5 255.255.255.255
ip address 45.45.45.5 255.255.255.0
ip router isis
ip address 56.56.56.5 255.255.255.0
ip router isis
router isis
net 49.0456.0000.0000.0005.00
router bgp 456
bgp router-id 5.5.5.5
network 5.5.5.5 mask 255.255.255.255
neighbor 45.45.45.4 remote-as 456
neighbor 45.45.45.4 route-reflector-client
neighbor 56.56.56.6 remote-as 456
neighbor 56.56.56.6 route-reflector-client
R6
interface Loopback0
ip address 6.6.6.6 255.255.255.255
ip address 36.36.36.6 255.255.255.0
ip address 56.56.56.6 255.255.255.0
ip router isis
router isis
net 49.0456.0000.0000.0006.00
router bgp 456
bgp router-id 6.6.6.6
network 6.6.6.6 mask 255.255.255.255
neighbor 36.36.36.3 remote-as 123
neighbor 56.56.56.5 remote-as 456
neighbor 56.56.56.5 next-hop-self
COMANDOS
Abaixo R1 mostra apenas um caminho para chegar em R4, R5 e R6
Router# sh ip bgp
BGP table version is 7, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 1.1.1.1/32 0.0.0.0 0 32768 i
*>i 2.2.2.2/32 12.12.12.2 0 100 0 i
*>i 3.3.3.3/32 23.23.23.3 0 100 0 i
*> 4.4.4.4/32 14.14.14.4 0 0 456 i
*> 5.5.5.5/32 14.14.14.4 0 456 i
*> 6.6.6.6/32 14.14.14.4 0 456 i
Router#
Enquanto que no R3 ele mostra 2 opções para chegar em R4, R5 e R6.
Router#sh ip bgp
BGP table version is 9, local router ID is 3.3.3.3
*>i 1.1.1.1/32 12.12.12.1 0 100 0 i
*>i 2.2.2.2/32 23.23.23.2 0 100 0 i
*> 3.3.3.3/32 0.0.0.0 0 32768 i
*> 4.4.4.4/32 36.36.36.6 0 456 i
* i 12.12.12.1 0 100 0 456 i
*> 5.5.5.5/32 36.36.36.6 0 456 i
* i 6.6.6.6/32 12.12.12.1 0 100 0 456 i
*> 36.36.36.6 0 0 456 i
Router#
1 Soluções Aceita
Soluções aceites
SamuelGLN
Nesse caso com 3 routers em cada AS é um design viável o Full-Mesh sim. O que pode testar também é simular uma queda entre R1 e R4 para validar se começará a receber as rotas de R4, R5 e R6 no router R1 atráves do R2(RR).
Ver solução na publicação original
3 RESPOSTAS 3
SamuelGLN
Olá @leandro1977, não sei se entendi bem o cenário só com as configs, mas acredito que isso ocorreu apenas por uma questão de design. R1 e R3 são os seus Ps, logo, eles devem fornecer os "caminhos" para o RR que por sua vez envia para os vizinhos client. Porém, se R3 recebeu as rotas de R4, R5 e R6 via EBGP com R6 e via R2(RR), o split horizon não irá permitir que ele anuncie de volta para o Router Reflector. Lembre-se sempre que rotas aprendidas de um non-client peer pode ser envia para eBGP peers e outros client-peers, mas nunca são enviadas para outro non-client peer. Por isso um non-client (R1) possui um caminho a menos que o outro non-client (R2).
Obrigado pelo retorno. Anexei a topologia. E se ao inves de usar RR, eu fizer um Full-Mesh em casa AS?
SamuelGLN
