cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Boot problem 2991
Near7314
I have this problem can anyone help me?
3 RESPOSTAS 3
balaji.bandi
Make sure you connected to console port - check the connection
I am guessing its console baudrate issue
what terminal software are you using ?
you can use putty as below : ( some time you need to change 9600 to increasin higer level) also change the COM1 to your environment.
BB
I changed the rate both higher and lower,and it didn't solve
Hi Near7314,
Please check remote character set as below. Keep it UTF-8 if different:
