cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Cisco Catalyst C1200 stacking
I’ve reviewed the official datasheet for the Cisco Catalyst C1200 Series but couldn’t find any mention of stacking support (either physical or virtual). Does anyone know if the C1200 series supports stacking in any way, for example, using uplink ports like the C1300?
If anyone has experience or clarification on this, I’d really appreciate it.
Thanks in advance!
1 Soluções Aceita
Soluções aceites
Jens Albrecht
Hello @gabriel.lima.caitano,
the reason for not finding any mentioning of stacking support is simple:
The Catalyst 1200 Series switches do not support stacking.
If you need the stacking feature, you need to take a look at the Catalyst 1300 Series switches which offer Front Panel Stacking capability for up to eight switches.
You can find more information about the Catalyst 1300 Series switches and their stacking capabilities here:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-1300-series-switches/nb-06-cat1300-ser-data-sheet-cte-en.html
HTH!
Ver solução na publicação original
4 RESPOSTAS 4
Jens Albrecht
HTH!
Hi everyone,
Thank you all for the quick and informative replies!
It’s now clear that the Catalyst C1200 series does not support stacking, either physical or virtual. I really appreciate the detailed explanations and the helpful links, special thanks to @Jens Albrecht, @Leo Laohoo, and @balaji.bandi for clarifying this.
Thanks again!
Leo Laohoo
Catalyst 1200 will never support stacking nor Horizontal Stacking.
Only the 1300 has stacking support.
balaji.bandi
As other members mentioned there is no stack support Cat 1200 model, if you not purchased already better look for upper model which support stack features.
If you already have and looking some alternative option look below admin guide :
Stack Topology
This module is a graphic representation of the stack topology and is identical in behavior to the Stack Topology View. It displays the following fields:
  • Stack Topology—Either Chain or Ring.
  • Stack Active—Number of units functioning as the active unit of the stack
https://www.cisco.com/c/en/us/td/docs/switches/campus-lan-switches-access/Catalyst-1200-and-1300-Switches/Admin-Guide/catalyst-1200-admin-guide/dashboard.html
BB
