cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
nat doesn't work
paulo-v-araujo
I'm trying to do a NAT, but isn’t working.
Basically i have a server with this IP 10.10.10.250 connected to Router 1 and I want to connect to this server from the other Router 2 that have a PC with the same IP 10.10.10.250.
Between the two routers I have another one Router 3 with a different IP 10.20.20.0/24.
How do i do a NAT in this case?
I tried ip nat outside source static 10.10.10.250 10.20.20.10, it doesn’t work, but I can ping it.
1 RESPOSTA 1
Hi @paulo-v-araujo
  You can do the NAT on the Router the PC is connected to.
ip nat inside source static 10.10.10.250  <router outside ip address>
You can also apply the NAT on the router that the server is connected to.
Apply ip nat inside and ip nat outside to the interfaces accordingly
