cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Problem between CBS350-24T-4X and SFP+ Mikrotik XS+2733LC15D.
mgonzalez76
Hello everyone, I wanted to tell you about a problem we are having when trying to connect two CBS350-24T-4X switches using their fiber ports. We are using SFP+ modules, Mikrotik brand, Model XS+2733LC15D.
Connectivity between the two devices is not established, and the ports are even blocked by Link Flap Prevention. We tested the same Mikrotik XS+2733LC15D SFP+ modules with Ubiquiti Switch without any problems.  We have disabled 802.3 Energy Efficient Ethernet (EEE), Link Flap Prevention and Smartport but the problem persists.
The Cisco Switch has Firmware Version: 3.4.0.17.
We would appreciate any help you can give us.
2 RESPOSTAS 2
Translator
Community Manager
Community Manager
Saudação
@O tradutor escreveu:
Switches CBS350-24T-4X . Estamos usando módulos SFP+, marca Mikrotik, modelo XS+2733LC15D., a conectividade entre os dois dispositivos não está estabelecida,
 Testamos os mesmos módulos Mikrotik XS+2733LC15D SFP+ com Switch Ubiquiti sem quaisquer problemas.
Parece um problema de compatibilidade com esses SFPs, a Cisco geralmente não suporta óptica de terceiros
Translator
Community Manager
Community Manager
Saudação,
tente usar o Cisco SFP+ ou algum terceiro confiável como a FINISAR
Esperança para ajudar
Giuseppe
