cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
13
Respostas
Problem with ACL
andrew005
Level 3
Level 3
Help me with ACL. I wrote the following commands, but computers from the Internet can still connect to the MAIN BUILDING and FILLIA 1 FILLIA 2 computers.
1 Soluções Aceita
Soluções aceites
If you add NAT, you can access the server using the router´s IP address. Take a look on the file attached.
Ver solução na publicação original
13 RESPOSTAS 13
andrew005
Level 3
Level 3
Project
@andrew005
  Did you apply the ACL to the right interface and right direction.?
@andrew005
Here one ACL that might work.
access-list 100 permit icmp 33.33.33.0 0.0.0.255 any echo-reply
access-list 100 deny ip 33.33.33.0 0.0.0.255 any
access-list 100 permit ip any any
Apply this ACL on the router 8, direction IN
interface FastEthernet2/0
ip address 33.33.33.1 255.255.255.0
ip access-group 100 in
duplex auto
speed auto
Internet host will not ping anything but will allow ping from other networks.
andrew005
Level 3
Level 3
@Flavio Miranda, Look, I configured ACLs in MAIN BUILDING, but for some reason I can't access the PUBLIC server through a browser, although TCP packets for it reach it. Everything is configured to access the server through the external port of the router.
From where to where exactly you can´t?
From PC2 to Server3
From PC22* to Server3 (PUBLIC in MAIN BUILDING)
Test the file I sent to you
Can you send me commands you write in?
Sorry I dont recall and I did not take notes. Take the show running config fro my file and compare with yours. It will be different
I can access the server from PC 2.
Now, if you are trying to access the server using the Router´s IP address, you dont have NAT for this.
Thank you!
