annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
8
Réponses
Cisco ASA FW (capture command) is not detecting existing UDP messages
Joerg.Teske
I have a question related to the interface of a Cisco router.
I have two cases of UDP flows arriving at a Cisco port (I can see them e.g. by connecting the ethernet cable to Wireshark on a windows PC).
The first case behaves as expected (with a capture command I see the UDP packages from 10.61.7.1 to 10.61.7.2case-ok.jpg
In the second case (source is not in the local LAN) I do not see the UDP packackes on the Cisco port (with a capture command I do NOT see any the UDP packages from 10.61.7.1 to  10.61.50.2
As written above, with Wireshark you can see that the UDP packages are visible on this interface.
Except to find a way to change the source address (has not intended impact) I do not see how I can change the definition of the interface:
interface GigabitEthernet1/1
  description interface
  nameif ifName
  security-level 10
  ip address 10.61.50.3 255.255.255.0
1 SOLUTION APPROUVÉE
Solutions approuvées
Thank you for the notes.
Finally I found the problem.
Due to a very big arp timeout (14400) and first connection of the equipment I did not see that the MAC was still not known.
Over night the problem was disappeared. Sorry for this fault (both cases are now working as expected).
Voir la solution dans l'envoi d'origine
8 RÉPONSES 8
Let check first case' how traffic between two host in same subnet hit FW interface?
What FW mode you run
MHM
Sorry, for sure:
Cisco Firewall ASA 5508 K9 (asa984-43-lfbff-k8.SPA )
Best regards
Jörg
friend I ask about the mode of operation
router or transparent
the traffic between two host in same subnet not need to pass via GW (in this case it FW)
MHM
For test the two elements are directly connected (Ethernet cable - no routing):
[cid:image004.png@01DA3F10.77093650]
Joerg.Teske
Updated figures:
check below notes
why ASA see traffic forward to other host not it interface ?
dont worry friend
Glad issue is solved
have a nice day
MHM
