annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
28
Réponses
Static routes redistribution in Nexus with OSPF
Rowlands Price
Hi support
I enable OSPF between Nexus switch and Catalyst, the ospf is up, but the issue is that Nexus doesn't redistribute it's static routes configure to ospf instance.
the static routes in nexus are bellow.
192.168.10.0 255.255.255.0 11.0.0.2
192.168.11.0 255.255.255.0 11.0.0.2
192.168.12.0 255.255.255.0 11.0.0.2
i need Nexus switch to redistribute the three statics routes to Catalyst, Can someone help me with the configuration
2 SOLUTIONS APPROUVÉES
Solutions approuvées
Show ip route
Show ip ospf database all
Show ip interface breif
Share this again after interface be UP.
Voir la solution dans l'envoi d'origine
It seem every thing is OK now'
Note:-keep all step we do for troubleshooting
1- we change area type
2-we add metric
In case later you need to back to modify it.
Have a nice weekend
MHM
28 RÉPONSES 28
Share config if you have
MHM
Hi MHM
Sorry, don't have config with me,
Then when you in site try
Under ospf
Redistrubte direct
And make sure static route in RIB of NSK.
MHM
Hi MHM,
I tried using route-map, but don't working, maybe somes mistakes
Route-map with redistrubte static under ospf ?
If yes
Use
Ip prefix-list dont use acl for route-map' NSK dont work with standard acl to filter prefix redistrubte between IGP/static.
MHM
Hi MHM
below is the config of the Nexus switch
ip route 192.168.10.0 255.255.255.0 11.0.0.2
ip route 192.168.11.0 255.255.255.0 11.0.0.2
ip route 192.168.12.0 255.255.255.0 11.0.0.2
vlan 406
name ZONE-BACKUP
vlan 407
name ZONE-BDD
vlan 408
name TEST
ip prefix-list STATIC seq 5 permit 192.168.10.0/24
ip prefix-list STATIC seq 10 permit 192.168.11.0/24
ip prefix-list STATIC seq 15 permit 192.168.12.0/24
route-map direct-to-ospf permit 10
match interface Vlan501 Vlan502 Vlan503 loopback0
route-map static-to-ospf permit 10
match ip address prefix-list STATIC
interface mgmt0
vrf member management
line console
line vty
boot nxos bootflash:/nxos.9.3.3.bin
no feature signature-verification
router ospf 1
router-id 10.4.80.206
area 0.0.0.10 stub no-summary
redistribute direct route-map direct-to-ospf
redistribute static route-map static-to-ospf
https://packetlife.net/blog/2008/jun/24/ospf-area-types/
Stub no summary area not accept lsa5/4.
Area direct advertise?
Change area to standard and check.
All other your config is correct.
MHM
hi MHM,
here the new config with the interface, just delete the stub area
interface Ethernet1/47
ip address 10.0.0.2/30
ip ospf network point-to-point
ip router ospf 1 area 0.0.0.0
no shutdown
interface mgmt0
line console
line vty
router ospf 1
but still not advertise static routes, connected routes are well working
Area now  is same in both peer?
Show ip route
Share output of above
MHM
Yes, are is the same in both peer,
ospf peering is working well, only Nexus doesn't redistribute static routes
Set metric 110
Set metric-type type 1
Add this under route-map of redistrubte and check.
Nexus not add it by defualt.
MHM
This before or after add set metric?
Show is for nexus that redistrubte static? If yes why route not appear in rib?
Before added metric Nexus redistributes connected network fine.
the issue is that from Calalyst, cannot see static routes configured on the nexus, so Nexus didn't redistribute it
match interface Vlan501 Vlan502 Vlan503 loopback0 Vlan500
set metric 110
set metric-type type-1
udld aggressive
ip dhcp snooping
service dhcp
ip dhcp relay
ipv6 dhcp relay
vrf context management
still not working, only connected network are redistributed
Below the sh ip route from Calalyst
