annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
NCS5500 - Activate ACL based on packet-length match
axelhauguel
Hello all,
I have read on some forums we need to activate some functions to have packet-length matching on ACL on NCS5500.
Révélation
RP/0/RP0/CPU0:core01.par2(config-ipv4-acl)#301 deny tcp any 89.116.164.0/24 packet-length eq 0
RP/0/RP0/CPU0:core01.par2(config-ipv4-acl)#commit
Fri Aug 18 23:31:42.797 CEST
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed [inheritance]' from this session to view the errors
RP/0/RP0/CPU0:core01.par2(config-ipv4-acl)#show configuration failed
Fri Aug 18 23:31:47.145 CEST
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
ipv4 access-list anti-ddos-in
!!% Parameter not supported in default ACL TCAM key, check syslog for more details: Following processes generated errors
!!% process : pfilter_ea pid : 3532 node : node0_0_CPU0 rc :'dpa_feat_mgr' detected the 'warning' condition 'Parameter not supported in default ACL TCAM key, check syslog for more details'
end
VERSION :  IOS XR 7.8.1
Anyone can help me please?
Thank you!
1 SOLUTION APPROUVÉE
Solutions approuvées
axelhauguel
Maybe solved ...
RP/0/RP0/CPU0:core01.par2(config-ipv4-acl)#hw-module profile tcam format access-list ipv4 src-addr dst-addr src-port dst-port proto packet-length frag-bit port-range
Sat Aug 19 00:06:47.487 CEST
In order to activate/deactivate this ipv4 profile, you must manually reload the chassis/all line cards
RP/0/RP0/CPU0:core01.par2(config)#
Voir la solution dans l'envoi d'origine
1 RÉPONSE 1
axelhauguel
Maybe solved ...
