annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Need help about Virtual IP configuration to forward traffics
Masna1
1 RÉPONSE 1
M02@rt37
Hello @Masna1
Do you please tell us a bit more about your request ?
Configuring a Virtual IP to forward traffic involves using a load balancer or a similar device to distribute incoming requests across multiple backend servers. First, determine the services or applications that will use the VIP and identify the backend servers that will handle the traffic. On the load balancer, create a VIP and assign it an IP address that clients will use to access the service. Configure the load balancing rules, specifying how the incoming traffic should be distributed (e.g., round-robin, least connections...). Associate the VIP with the backend servers by defining a server pool or group and adding the IP addresses of the backend servers. Ensure the health checks are set up to monitor the availability of backend servers and configure the appropriate protocols and ports for the VIP.
Best regards
