annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Problem of connection to the router ASR920 IM
oussama rezig
Hello All ;
I'm encountering an issue in the ASR 920 I'M router:
After boot up of the router , it display a message with 'Press RETURN to get started'. But after hitting return ، nothing happen.
the same in the bios mode " rommon " the system stoppe in the rommon1 >
as shown in the log below  , so i loss the access to the router in the two modes' privileged & rommon ' in order to pushe the rest configuration.
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
Passing control to the main image..
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 5 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 7 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 8 contained errors which were auto-corrected.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.5(3)S2a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 18-Feb-16 23:08 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR-920-12SZ-IM (Freescale T1042) processor (revision 1.2 GHz) with 919000K/6147K bytes of memory.
Processor board ID CAT2029U10J
12 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4193280K bytes of physical memory.
3304223K bytes of SD flash at bootflash:.
Press RETURN to get started!
The problem is i don't  have an access to the line command in the two modes' privileged & bios  for do the reload command or any things.
for the  normal state , when I turn on the router in the normal state, the system stops in the
and when I access to the bios mode the router stops on this line :
Rommon 1 >
Please how I can solve this issue.
Br
1 RÉPONSE 1
Bonjour,
En voyant "%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.".
A mon humbke avis il faut avoir une vérification du matériel . Vous êtes en contact avec un distributeur Cisco ?
*** Obtenez des réponses techniques plus rapidement : Vidéo (15 min. fr) Visitez mon Blog technique. ***
