annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
15
Compliment
Réponses
Tunnel IPSEC - Assistance sur un problème de communication de routage sur Cisco C892FSP vs Palo Alto
Oligano
Pour expliquer mon problème rapidement, je n'arrive pas à faire circuler la plage IP "172.25.5.0 0.0.0.255" dans le tunnel IPSec.
De l'autre côté, le tunnel est monté et fonctionnel. Je parviens à faire transiter le flux 10.0.0.0/8 vers 10.15.0.0/16.
La configuration de mon cisco:
crypto isakmp policy 1
encr aes 256
hash sha256
authentication pre-share
group 5
lifetime 28800
crypto isakmp key 6 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX address 1.111.1.111
crypto ipsec transform-set rtpset esp-aes 256 esp-sha256-hmac
mode tunnel
crypto map rtp 1 ipsec-isakmp
set peer 1.111.1.111
set transform-set rtpset
match address 115
interface GigabitEthernet0
switchport trunk native vlan 1001
switchport mode trunk
no ip address
spanning-tree portfast
interface GigabitEthernet8
ip address 123.123.123.123 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex full
speed 1000
crypto map rtp
interface Vlan1
no ip address
shutdown
interface Vlan1001
description Backbone
ip address 10.100.10.110 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat pool WanSFR 123.123.123.123 123.123.123.123 netmask 255.255.255.248
ip nat inside source route-map nonat interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 123.123.123.123
ip route 10.15.0.0 255.255.0.0 10.100.10.110
ip ssh logging events
ip ssh version 2
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm mac hmac-sha2-256
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip access-list extended LAN
permit ip 10.15.0.0 0.0.255.255 any
route-map nonat permit 10
match ip address 110
access-list 110 deny ip 10.100.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 110 permit ip 10.100.0.0 0.0.255.255 any
access-list 110 deny ip 10.15.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 110 deny ip 10.15.0.0 0.0.255.255 172.25.5.0 0.0.0.255
access-list 110 permit ip 10.15.0.0 0.0.255.255 any
access-list 115 permit ip 10.120.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 115 permit ip 10.15.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 115 permit ip 10.15.0.0 0.0.255.255 172.25.5.0 0.0.0.255
3 RÉPONSES 3
Oligano
Résultat d'un sh crypto ipsec sa:
interface: GigabitEthernet8
Crypto map tag: rtp, local addr 123.123.123.123
protected vrf: (none)
local ident (addr/mask/prot/port): (10.15.0.0/255.255.0.0/0/0)
remote ident (addr/mask/prot/port): (10.0.0.0/255.0.0.0/0/0)
current_peer 1.111.1.111 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 271252562, #pkts encrypt: 271252562, #pkts digest: 271252562
#pkts decaps: 335397886, #pkts decrypt: 335397886, #pkts verify: 335397886
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 1126
local crypto endpt.: 123.123.123.123, remote crypto endpt.: 1.111.1.111
plaintext mtu 1438, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet8
current outbound spi: 0xE5683D6A(3848813930)
PFS (Y/N): Y, DH group: group5
inbound esp sas:
spi: 0x4B51388(78975880)
transform: esp-256-aes esp-sha256-hmac ,
in use settings ={Tunnel, }
conn id: 567, flow_id: Onboard VPN:567, sibling_flags 80000040, crypto map: rtp
sa timing: remaining key lifetime (k/sec): (4283283/2198)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 568, flow_id: Onboard VPN:568, sibling_flags 80000040, crypto map: rtp
sa timing: remaining key lifetime (k/sec): (4332814/2198)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
local ident (addr/mask/prot/port): (10.120.0.0/255.255.0.0/0/0)
#pkts encaps: 468158, #pkts encrypt: 468158, #pkts digest: 468158
#pkts decaps: 344671, #pkts decrypt: 344671, #pkts verify: 344671
#send errors 0, #recv errors 0
current outbound spi: 0xB2F6802F(3002499119)
inbound esp sas:
spi: 0xE333F197(3811832215)
conn id: 569, flow_id: Onboard VPN:569, sibling_flags 80000040, crypto map: rtp
sa timing: remaining key lifetime (k/sec): (4252130/2751)
IV size: 16 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 570, flow_id: Onboard VPN:570, sibling_flags 80000040, crypto map: rtp
sa timing: remaining key lifetime (k/sec): (4252102/2751)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
remote ident (addr/mask/prot/port): (172.25.5.0/255.255.255.0/0/0)
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#send errors 2031, #recv errors 0
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet8
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
Au niveau du palo Alto, aucune échange sur la plage 172.25.5.0/24
Bon, je viens de résoudre mon problème...
Je n'arrive pas à comprendre pourquoi cela fonctionnait pour la plage 10.0.0.0/8 et non pour 172.25.5.0/24, mais bon..
Tout d'abord, j'avais des informations sur Cisco et Palo Alto, qui m'avertissait un problème de communication dans la Phase 2 IKE.
Message d'erreur sur Cisco:
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/115801-technote-iosvpn-00.html
Message d'erreur pour Palo Alto:
https://docs.paloaltonetworks.com/pan-os/7-1/pan-os-admin/vpns/site-to-site-vpn-concepts/set-up-site-to-site-vpn/interpret-vpn-error-messages
En résumé:
j'ai activé PFS et modifié lifetime de la phase 2 pour être en lien entre les deux configurations IPSEC Crypto.
j'ai modifié les ACL
access-list 110 deny ip 10.100.0.0 0.0.255.255 172.25.5.0 0.0.0.255
access-list 110 permit ip 10.110.0.0 0.0.255.255 any
access-list 115 permit ip 10.100.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 115 permit ip 10.100.0.0 0.0.255.255 172.25.5.0 0.0.0.255
A présent, c'est fonctionnel et a permis de corriger les problèmes de communication SA.
Cordialement
