annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
unity connection and CUCM
kingstdz
I have CUCM and unity connecion, configured auto attendent, work fine for XXXX extention in local side CUCM cisco, but when i give it XXXX XXXX of other side may be CISCO or ALCATEL (distant) does not work.
how i can config it and where in CUCM (it has route and plan ) or in unity connection?
i have mp3 réception (welcome) how i can transfert and codec it to unity connection?
thanks
1 SOLUTION APPROUVÉE
Solutions approuvées
M02@rt37
Hello @kingstdz
As for transferring your MP3 reception to Unity Connection, you will need to first convert the file to a compatible format such as WAV or AU. Once you have the file in the correct format, you can upload it to Unity Connection using the Media Master tool. From there, you can set up a call handler and configure it to play the uploaded recording as the greeting message.
Best regards
Voir la solution dans l'envoi d'origine
2 RÉPONSES 2
M02@rt37
Hello @kingstdz
Best regards
thanks M02@rt37
it work but i have changed call handler default of button voicmail how i can create another call handler and affect it to button voicemail
when user clic button voicemail, he can read message or other.
thanks
