annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
FW ASA5506 PAT not applied issue
M-AHMED
Topology.jpgHello everybody,
Iam trying to config a PAT on ASA5506 for my network (Labo CCNA) .
Finally PAT rules is not applied on packets, its forwarded without any change.
you can find attached running-config of ASA5506.
FW#show running-config
: Saved
ASA Version 9.6(1)
hostname FW
domain-name wr
enable password J.WhuVJ1RokggMhD encrypted
names
interface GigabitEthernet1/1
 nameif insider2
 security-level 100
 ip address 10.0.0.10 255.255.255.252
interface GigabitEthernet1/2
 description Link to R1
 nameif insider1
 security-level 100
 ip address 10.0.0.14 255.255.255.252
interface GigabitEthernet1/3
 no nameif
 no security-level
 no ip address
 shutdown
interface GigabitEthernet1/4
 no nameif
 no security-level
 no ip address
 shutdown
interface GigabitEthernet1/5
 no nameif
 no security-level
 no ip address
 shutdown
interface GigabitEthernet1/6
 no nameif
 no security-level
 no ip address
 shutdown
interface GigabitEthernet1/7
 no nameif
 no security-level
 no ip address
 shutdown
interface GigabitEthernet1/8
 nameif outside
 security-level 0
 ip address 209.165.201.1 255.255.255.252
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
 shutdown
object network VLAN10
 subnet 192.168.1.0 255.255.255.0
 nat (insider1,outside) dynamic interface
object network VLAN20
 subnet 192.168.2.0 255.255.255.0
object network VLAN30
 subnet 192.168.3.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 209.165.201.2 1
access-list OutSide-Access extended permit tcp any any
access-list OutSide-Access extended permit icmp any any
access-group OutSide-Access in interface Outside
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect icmp
  inspect tftp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
router ospf 10
 router-id 3.3.3.3
 log-adjacency-changes
 network 10.0.0.20 255.255.255.252 area 0
 network 10.0.0.8 255.255.255.252 area 0
 network 10.0.0.12 255.255.255.252 area 0
1 RÉPONSE 1
Richard Burts
I see where you define objects for vlan10, vlan20, and vlan30. But I do not see anything that says where those are or about how to route to/from them.
Rick
