annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Switch CBS350, value of OID for temperature
loicderiv
I'm using cisco CBS350 switches, I'm looking for the OID for the switch temperature.
I was able to retrieve some information "1.3.6.1.2.1.47.1.1.1.1.2.68421377 = STRING: "Thermal Sensor" for example.
However, the value linked to this oid is "68421120". How can I convert it into degrees?
How can we be sure that the value reported is actually that of the switch?
Thank in advance
1 RÉPONSE 1
C'est bizarre car j'ai fais quelques recherches et voici ce que j'obtiens pour le début de l'OID:
OID 1.3.6.1.2.1.47.1.1.1.1.2
Module ENTITY-MIB (CISCO)
Nom entPhysicalDescr
Acces readonly
Status current
Description A textual description of physical entity. This object should contain a string that identifies the manufacturer's name for the physical entity, and should be set to a distinct value for each version or model of the physical entity.
Syntaxe SnmpAdminString (SNMP-FRAMEWORK-MIB)
*** Obtenez des réponses techniques plus rapidement : Vidéo (15 min. fr) Visitez mon Blog technique. ***
