Application Deployment Failed:Package signature file not found in package
Justin Chin-You
Hi All,
Just wondering, has anyone ever come across this message?
Application Deployment Failed: Package signature file package.cert or package.sign not found in package
Trying to deploy a C Based Application on my IR829.
Justin Chin-You
Incase anyone else runs into this, I was running IOS version 15.7(3)M and it appears that "Signed Packages" are now enabled by default.
To resolve this, you can disable the signed package requirements:
1) Log into IOX Manager
2) System Settings -> Application Signature Validation -> Uncheck "Enabled"
Justin Chin-You
can't fix it
