Edge Computing Infrastructure
Labels
Hey,I have a catalyst 8300 router and I upgraded the code from 17.09.04a to 17.13.1a.  Now my ubuntu kvm virtual service will not activate.  I've uninstalled and attempted to reinstall the ova file, i even tried an earlier version i created that i kn...
Hi Team,I am unable to create docker image for the Cisco XRv 9000 Routers, IOS XR Release 25.4.1 in Containerized Lab(CLAB) server which is running Linux based on Red Hat Enterprise 9.4 as mentioned in release note link below, while I tried to create...
Karthila by • Community Member
  • 1045 Views
  • 1 replies
I am atttempting to run a Linux VM in IOx on a C8200 platform.  The container log shows that it is starting with option:-machine pc-0.13,accel=kvm,usb=off,dump-guest-core=offand complains:2025-10-21T17:11:14.773544Z qemu-kvm: Machine type 'pc-0.13' i...
thock by • Visitor
  • 3011 Views
  • 6 replies
Hi all,I'm trying to run a python script in a docker container on the IR829 and whenever I try to start the application I get this error:$ioxclient application start mainCurrently active profile :  defaultCommand Name: application-startSaving current...
mardunca by • Community Member
  • 6231 Views
  • 6 replies
Hello,I am new to Cisco IOx and I am trying to run a Helloworld app on a Cisco IR1101 router with Cisco IOS XE Software, Version 17.03.01.I am following the information and using the files from a guide on github: https://github.com/etychon/iox-aarch6...
OGuler by • Visitor
  • 4208 Views
  • 3 replies
