CAF not running but Guest OS/Linux working
patelvc7601
I am out of resources.
I have IR809 with 156-2.T3 with ioxvm 1.3.0-T.bin for the Guestos. I have tried 1.2.4.2-T.bin with the same issue.
I can access the Guest OS but CAF is not working.
root@IR800-GOS-1:~# monit summary
The Monit daemon 5.14 uptime: 35m
Process 'dmo'                       Running
File 'product_id'                   Accessible
File 'hwid'                         Accessible
File 'svcbr0'                       Accessible
File 'ioxcaps'                      Accessible
Process 'caf'                       Not monitored
File 'cgroup'                       Not monitored
System 'qemux86-64'                 Running
Running monit start caf does not help.
I have change the product_id to match show inventory of the Cisco IOS
Also change the /etc/hosts file with no luck.
log file caf.log shows
MissingSectionHeaderError: File contains no section headers.
file: /software/caf/cartridges/load.ini, line: 2
'export CAF_HOME="dirname $0" \n'
2017-10-04 13:44:56,857 [runtime.service:INFO] [MainThread] [runtime.py:809 - stop()] Stopping CAF Runtime Service
2017-10-04 13:44:56,859 [taskmgmt:DEBUG] [MainThread] [taskmanager.py:92 - revoke()] Revoking task with task id:None
2017-10-04 13:44:56,861 [taskmgmt:DEBUG] [MainThread] [taskmanager.py:119 - get_task()] Get task None from task registry
2017-10-04 13:44:56,861 [taskmgmt:DEBUG] [MainThread] [taskmanager.py:92 - revoke()] Revoking task with task id:None
2017-10-04 13:44:56,863 [taskmgmt:DEBUG] [MainThread] [taskmanager.py:119 - get_task()] Get task None from task registry
2017-10-04 13:45:06,098 [runtime:INFO] [MainThread] [bootstrap.py:54 - __init__()] Extra log config file is at : /software/caf/work/ext-log-config.ini
2017-10-04 13:45:06,332 [runtime.service:INFO] [MainThread] [runtime.py:183 - __init__()] System ID matches with stored ID in /software/caf/work/device_id
2017-10-04 13:45:06,343 [runtime.service:ERROR] [MainThread] [runtime.py:305 - __init__()] File contains no section headers.
Steve Zhang
Could you please try the workarounds in Can't Connect to IOx Local Manager - 15.6.3M2 - IR829?
patelvc7601
I have seen the forum & changed the product id & other remedy suggested in the release notes with no luck
Working with TME/Frank from Cisco . I used the latest bundle ir800-universalk9-bundle.SPA.157-3.M.bin
which allowed me to access Iox local manager but some tab was missing , so finally Frank suggeted to reformat the partition using following .
guest-os 1 disk-repartition 1
& that worked .
Sincerely
Viral Patel
