Configuring IR809 for One Cisco LoRaWAN Interface Module
vaidee@divum.in
Community Member
We are currently working with the Cisco IR809 Gateway and its Integration with the LoRa Modem / LoRaWAN server.  While we have successfully installed the latest IOX , Setup the Ethernet Interface Config (GE0) and also setup the DHCP Pool for LoRaWAN Interface Module , We are still not clear in Setting Up the Virtual-LPWA and its Packet Forwarder.   What I have learnt so far is that we have to install a package forwarder Firmware and configure it with the public key of our LoRaWAN server to proceed further. But Im not able to choose and deploy a packet forwarder firmware in the Modem.
The Document Says this,
IR809#configure terminal IR809(config)#interface virtual-LPWA 1
IR809(config-if)#lpwa packet-forwarder public-key flash:lrr-1.4.24.pubkey
IR809(config-if)#lpwa packet-forwarder firmware flash:lrr-1.6.11-ciscoms_config.cpkg auto-install if-not-installed
IR809(config-if)#lpwa modem environment PKTFWD_ROOT /tmp/mdm/pktfwd/firmware/
IR809(config-if)#exit IR809(config)#end IR809#write memory
But My Problem is that , Where can i get the lrr-1.6.11-ciscoms_config.cpkg ??
And is the file lrr-1.4.24.pubkey my LoRaWAN Server's public key ?? If not where can i get them ??
Steve Zhang
