Error while executing a makefile named as "makefile"
darshan.sr1
Community Member
1.Have written the code factorial.c as said in the document 819-IOx-SDK-cookbook.
2.Have created the make file named "makefile".
Path of SDK- /opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/
path of my example programs(followed the procedure of cookbook) - /home/user/iox_c/src
Error is as follows
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1//tools/toolchain/powerpc-linux-gnu/bin/powerpc-linux-gnu-gcc -te500v2 -L/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1//tools/toolchain/powerpc-linux-gnu/powepc-linux-gnu/libc/lib -L/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1//tools/toolchain/powerpc-linux-gnu/powerpc-linux-gnu/lib/gcc/powerpc-linux-gnu/4.5.1/ -o "factorial.bin" factorial.o
factorial.o: In function `_start':
(.text+0x0): multiple definition of `_start'
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/tools/toolchain/powerpc-linux-gnu/bin/../powerpc-linux-gnu/libc/te500v2/usr/lib/crt1.o:(.text+0x0): first defined here
factorial.o: In function `_fini':
(.fini+0x0): multiple definition of `_fini'
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/tools/toolchain/powerpc-linux-gnu/bin/../powerpc-linux-gnu/libc/te500v2/usr/lib/crti.o:(.fini+0x0): first defined here
factorial.o:(.rodata+0x10): multiple definition of `_IO_stdin_used'
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/tools/toolchain/powerpc-linux-gnu/bin/../powerpc-linux-gnu/libc/te500v2/usr/lib/crt1.o:(.rodata.cst4+0x0): first defined here
factorial.o: In function `__data_start':
(.data+0x0): multiple definition of `__data_start'
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/tools/toolchain/powerpc-linux-gnu/bin/../powerpc-linux-gnu/libc/te500v2/usr/lib/crt1.o:(.data+0x0): first defined here
(.data+0x4): multiple definition of `__dso_handle'
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/tools/toolchain/powerpc-linux-gnu/bin/../lib/gcc/powerpc-linux-gnu/4.5.1/te500v2/crtbegin.o:(.data+0x0): first defined here
factorial.o: In function `_init':
(.init+0x0): multiple definition of `_init'
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/tools/toolchain/powerpc-linux-gnu/bin/../powerpc-linux-gnu/libc/te500v2/usr/lib/crti.o:(.init+0x0): first defined here
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/tools/toolchain/powerpc-linux-gnu/bin/../lib/gcc/powerpc-linux-gnu/4.5.1/te500v2/crtend.o:(.dtors+0x0): multiple definition of `__DTOR_END__'
factorial.o:(.dtors+0x4): first defined here
/opt/ciscoiox/cisco_iox_sdk-x86_64-v0.1/tools/toolchain/powerpc-linux-gnu/bin/../lib/gcc/powerpc-linux-gnu/4.5.1/../../../../powerpc-linux-gnu/bin/ld: error in factorial.o(.eh_frame); no .eh_frame_hdr table will be created.
collect2: ld returned 1 exit status
make: *** [factorial.bin] Error 1
Attached:
factorial.c
makefile
Need help in understanding the error and debugging it.
darshan.sr1
Community Member
Hi ,
Problem solved by "make clean".
Darshan.S.R
Steve Zhang
Hi Darshan,
It should be working well if you follow the Cook book.
Regarding the error, could you please check your Makefile? I guess the error is caused by the LDFLAGS. There should be blankspaces before "\" in LDFLAGS.
Steve
Hi Steve,
Thanks for the reply. Solved it.
Is there any detailed explanation of running the OVA files on Vmware or VMbox??
Duplicated. See the reply in Running .ova files on Oracle VM virtual box
