Execute a script from persistent partition after guestOS bootup
arun1587
Frequent Visitor
Frequent Visitor
Can I run a script that is stored in /software/downloads/,  which is persistent across reloads of the router, after the guest OS comes up?
I use IR829 router with 15.7(3)M2 ios, and Host OS Version: 1.6.3.1
thanks,
Steve Zhang
Hi, Cisco does not recommend to run the scripts in GOS directly. Basically all the apps should be running as IOx apps.
Steve Zhang
Thanks for the info.
