IR 829 bad record mac
giuseppe.palmieri961
Community Member
I'm trying installing a package on IR829 but i'm getting this error from IOXclient and Fog director:
     Error processing command :  Post https://10.10.20.2:8443/iox/api/v2/hosting/apps: remote error: bad record MAC
I've already tried to uninstall and reinstall the guestOS image but with no success. What can couse this error?
Steve Zhang
HI Giuseppe,
Could you please check if GOS is started successfully (show iox host list detial in IR829 IOS)? And please follow the guide of IR 8xx Platforms - IOx Docs
Hope it helps.
Steve
Yes GOS is running, Local Manager is reachable and also the fog director can reach the ir829.
The problem comes out just while installing apps. I'm not sure but it might be happening after enabling ssh on the router but now even resetting the configuration it is still coming up.
All other operations seems working correctly (Start, Stop, uninstall...)
I also have another ir829 that's working and configurations on the IOs seems to be almost identical.
Giuseppe
