Is there a way call IOx from IOS? (Atomic IOx updates)
GarySmith
Our problem with IOx is making atomic updates to IOx agents on multiple routers (100+) over an unreliable network.
To publish an update to an App we potentially have to:
  • Possibly get current config & edit
  • Stop App
  • Deactivate App
  • Upgrade App
  • Activate App
  • Possibly set new config
  • Start App
Any of these steps can fail and, crucially, they may fail midway - after you have stopped or deactivate an App that you can then no longer activate/start due to network problems.
We were wondering about a solution that downloads all necessary data (package & config) locally to the router (829) and then uses IOS to talk to IOx and make the changes.
Thoughts?
Alexander Stevenson
I'm not sure, but "IOx Infra does communicate with the IOS through ICC (inter-core communication) for interacting with devices:
Access to network
Receive CLI config/exec statements (from IOS config)
Access to storage/flash (through NFS).
IOx (based on Linux) is bootstrapped by IOS at system bootup."
source: https://developer.cisco.com/docs/iox/#!isr-800-series
