LoRaWAN GW GUI.
yahya.jaber
Level 2
Level 2
Hi All,
Does Cisco GW has GUI? same as Laird GW's? can we configure it as a packet forwarder or a server?
can we add sensors on it? how does it work?
yahya.jaber
Level 2
Level 2
Hello?
Alexander Stevenson
If by GW, you mean Gateway, then yes. Cisco switches, routers and gateways can now have GUI, although it might depend on the model.
Here's an example: https://www.cisco.com/c/en/us/td/docs/cable/rf_gateway/feature/guide/rfgw10_gui.html
According to the Release Notes for the Cisco LoRaWAN Gateway, Release 2.1.0.2, they added support for Common Packet Forwarder (CPF).
As far as adding sensors, please see this discussion: How to deploy LoRaWAN gateway and sensor?
