Bluetooth Settings
vassallon
Level 7
Level 7
I can't wait for Meraki to get this rolled out so I can finally be sure student iPads have Bluetooth always enabled for Apple Classroom to work and allow students to pair Bluetooth devices.
Bluetooth Modifies the Bluetooth Setting
To send a Bluetooth command, the server sends a dictionary containing the following keys:
KeyTypeContent
Item
String
Bluetooth.
Availability: Available in iOS 11.3 and later for supervised devices and in macOS 10.13.4 and later.
Enabled
Boolean
If true, enables Bluetooth.
If false, disables Bluetooth.
Found this helpful? Give me some Kudos! (click on the little up-arrow below)
16 Replies 16
jared_f
Level 7
Level 7
I know the bluetooth restriction locks the toggle off if it is set to off when the configuration profile is pushed. But it doesn't allow other devices to be paired? Very stupid on Apple's part. Would it be possible to use the Meraki API to send the bluetooth on command to all devices every "x" minutes? I would set it to two minutes and eventually people would just get tired of turning it off.
Find this helpful? Click the kudos button. Thanks!
Wish this was possible
